Getiing a fault code 34-11 . Changed the cable connections, tried different IO board and even tried different blower motor. Any ideas or suggestions ?
Printable View
I'd have to consult our service manuals to even know what that code is. I take it you already do know?
What's your model number? If it's an old CCC, I wouldn't be much help. Otherwise, I'll do what I can to assist.
Not on site atm for model number. Its the newer touch screen. The codes from what i read are a total to equal the 11. If i remember correcty it was 8,2 and 1. Also the yellow light is flashing on the IO
Okay. Sounds like the SCC series. I'll do some checking...
Need the model number. Do a function test to see which componenent is not working?
I have the manual for the SCC line. And a service 34 is a BUS code could be (I/O pcb, bottom motor, top motor, or ignition box).
Check the ignition box!
