Not going to happen. Bigger hoses and better quality stuff is going to speed things up IMO. If someone finds hoses that will hold a vacuum that would be a great find. I might feel remorse from the manifold purchase but you shouldn't with the hoses. If you didn't have bigger ones already it is going to speed up the job. If you rig your rig for isolation of the hoses, manifold and pump on a real system you should be much happier with what you have there. If you plan on following the "rules" to the letter you will be happier listening to the pump. If you know your pump I believe its a good indication of how you're doing. Start on a MO system then go to a poe system if you want to be disappointed again :grin2:
