Originally Posted by
rk05
I have not had a call back yet from this contractor about the load calc and they even talked to me about doing them at the home show that I meet them through.
This contractor did not say much about the duct work but a previous one did say the duct work should handle 3-tons but he didn't do any calcs either. He did say I should reroute the line that comes off the top of the plenum to our basement bath. Something about too much pressure at the top and the line should come off the side?
I want a 10yr parts and labor regardless of manufacture.
I had a energy audit done and showed this last contractor the results. The ACH were .64 if I remember correctly. He didnt look at it that much.
I am doing my basement remodel at the same time or before a new system is installed and I will be sealing up the rim joist with spray foam to help seal up the house. That is why I was thinking I could lower the system.
I would like to get 3 quotes to compare but how likely will it be for all three to actually do the manual j? I don't want to waste their time but I also want the correct size system, hopefully a smaller one.
