Advice on 3.5 Ton 15 Rheem Unit
Hello,
I live in Northeast Florida and I am in the market for a new Air Handler and Compressor. I have been researching Rheem and Carrier 3 Ton Units. I did some cost analysis on both and found that the 15 seer Comfort Series unit was the only cost effective unit. It would only take me 4.7 years to recoup the difference in cost between the 15 seer unit and the 13 seer unit. I used a calc I found on line at XYZ.com to determine how long it would take me to recoup my initial cost of the units compared to the minimum 13 seer Unit. I could not justify spending $$k vs. $k for the less expensive units. With the 16 seer it would take me 30 years to recoup my initial outlay. With the 19 seer a little over 19 years and the 20 seer 20 years. The units just do not last that long this close to the beach to justify spending that much money for a unit that probably at best will last me 10-13 yrs. Any thoughts on this? My calc is as follows:
-36,000 BTU divided by Seer Number= Watts
-Watts divided by 1000 = x thousand watt units which is the number of kwh your air conditioner consumes each hour
-Then Determine the number of hours annually that your unit will be operational based on your geographic location. In Florida it is about 2500 hours annually.
-Multiply the number of kwh your air conditioner consumes from step 2 above x the number hours annually your unit is operational = KWH annual consumption
- Now you convert this figure to annual cost. You take the KWH annual consumption and multiply it by cost of each KWH which can be found on your electric bill. In my area of Northeast FL the cost is .12041 per kwh
Answer to my question on finding most cost effective three ton ac unit
Quote:
Originally Posted by
BaldLoonie
If initial cost is an issue, Rheem's 14AJM value line gets 15-16 SEER with high efficiency air handlers. Yes, above 15 SEER getting into 2 stage units, the price gets steep and the payback isn't there. The 3 ton with RHKL-HM3821 you get 16 SEER rather affordably and a nice 13 EER. I think that gets you some tax credit and check for utility rebates.
Thanks BaldLoonie for the information. Cost should always be an issue with everyone. If it is not you probably will end up paying too much for something. I like to purchase things that bring me value. There is just no value in those higher end Infinity units to me. I will take a look at the Rheem product you suggested and run a cost analysis on it.
I do have another question for you if you do not mind? Is there any credentials that a good HVAC installer should have. I have been reading that most of the lower end units components are very similar and what really matters is the installation and warranty. I am just wondering how I know when I choose a AC contractor that his install people are going to know what they are doing. Is there any license or certificate they should have? Thanks for your help. Also do you recommend purchasing an extended warranty on a new AC unit?
