No DIY. Read the rules.
Call a professional before you hurt yourself, your family, or your equipment.
Printable View
So, let me see if I have this right...
You diagnosed a bad motor and replaced it yourself. Now the new motor is doing the same thing. Now because its drawing 120v, you have decided its not a wiring issue. Since you can do this yourself, you ask us what motor you should buy next?
I've always liked General Motors. My Chevy purrs like a champ. Recently I've been considering getting a hemi...
Okay, that's not nice. Do you get the point? Hire a tech. Or keep buying motors and expect different results with each new one...
This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here. Please apply to the AOPC today, thank you.
Further infractions may result in loss of posting privileges.
Okay I got it about replacing a motor with less amps. I see I can replace a motor with the same amperage as old and all will be good. But considering they have more efficient motors now with less amperage I should be able to use resistors and use a motor with less amperage, right? This way i'll be able to save energy costs.
I'm moving in a couple months anyways so either is not a huge deal, but what is the best option?
Also, I appreciate the help that forums like these provide. But it is upsetting that this forum puts limits and restrictions on help, for the sole purpose to push people to hire people in your profession. This might be the only forum I've ever been on that limits the assistance and is so negative on assisting others.
I'm an IT consultant by trade, and My profession is similar to yours, I fix things that are broke, or provide solutions to enhance things. I work for a small company that works for other small companies, because I like helping people. Our company with just about any IT related forum go out of our way to assist others and never limit our assistance for any reason.
Justin,
Playing around with an Ethernet cable is not the same as playing around with high voltage. IT forums are not the same as this.
While you may be capable or repairing your systems yourself, others aren't. Someone will google their problem and bring up this exact thread. Then that person hurts themselves or others because they're not properly trained.
That is a risk that neither myself or this website wants to deal with.
And from what I've read, you should stick to IT. HVAC isn't your thing.
Wrong network switch or a bad gateway won't burn down a house guy.
Your still not seeing my point about the different amps. Use resistors?? Come on. You really shouldn't be tackling this one!
Did you feed the squirrel? Maybe that's what's going on?
did you replace the capicitor with the correct size for the new motor
