Thanks, much appreciated
Printable View
Probably gonna need to be bigger then what you would normally run so as to keep grille noise down.
It just dawned on me that my 3000 cfm inline blower may not be powerful enough to pull air out through newly built ventilation network for 6-8 rooms. This is way over my head and I am afraid that I just wasted great deal of money on my blower and would have to buy a bigger one. Plz, tell me that I am wrong and that blower would be sufficient.
What ESP/static is it rated to work against. it should list CFM at several different statics.
Probably get between 20000 and 2400 CFM.
What is wrong with one central location? How do you know they are not powerful enough? What happens with your design when some bedroom windows are closed? Where will it suck the additional cfm from? I am as confused as you. I have installed many of these and they are very quiet. I was trying to help by giving you an option. I did not think I was being anything but helpful. Good luck.
What you need is a VFD exhaust fan with a building static sensing device that will increase / decrease fan speed (cfm) with sensed restrictive pressure.
Very smart and sensible suggestion, indeed. The real question is, - are they produced / manufactured here in USA / Japan or Europe? So far, I saw only constant speed varieties from guys like Soler / Fantech, Greenheck..etc. I flatly refuse to buy anything from China, especially mechanical devices requiring high quality bearings and other hi quality important components.
First of all, my sincere apologies if you sensed or felt that I was rude toward you; nothing of that sort of behavior was intended. Secondly, in my current design it will never happen because WHF fan will be turned on only manually after remote humidity and temp sensors will alert / notify my computer that conditions are right to turn WHF on and all windows will be opened. I know what you are going to tell me, - if nobody is there to open windows, fan will never be turned on and I'll be clearly wasting a perfect opportunity to cool the house with cool outside air. Well seems like a better alternative to anything else.
Of course, there is always another option, like for instance, forget all about stupid windows and build a closed loop system drawing air from inside and supplying it from outside through huge supply vent. In this case I can go fully automatic and I will never depend on open/closed windows in my life. Are you catching my drift?
