Originally Posted by
jtrammel
New construction is very "cut throat" especially in a tract home situation. Every corner is cut to keep costs low because the builder tries to keep costs low, ductwork usually suffers to keep costs low as well as inexperienced installers to keep labor cost low. If it was a custom built home then the hvac sub should have met with you and the builder and given you options and gotten input from you about how important certain things such as IAQ, humidity etc is to you and your family. A good duct system installed per manual D would have balancing dampers at each branch line on the trunk line that would be balanced and set when installed to match the heat gain/loss calculated by manual J of the room.
