Originally Posted by
newathvac
The outdoor fan has been running nonstop. It only shut off once today when it was in defrost mode.
Also, the unit outside has been loud all day. It usually gets quiet but today it has been loud. Is it because it is cold, 32 degrees or so? I just found it odd that it has been loud since it usually isn't.
You said at the beginning of your post that the outdoor unit will shut off if it meets the desired temperature, but at the end of your post you said it will try to maintain the temperature without shutting off. I don't understand.
Thank you, I appreciate you explaining how the system works.
