Turn on gas, turn on valve, flip switch. If it does nothing then you have a problem.
Sent from my iPad using Tapatalk HD
Printable View
You have been a ton of help qwerty thanks,
I have done it in that process and nothing has happened, is there anything that I can do or check that can be in the scope of a diyer? I like to support my skilled traders but if its something that is manageable this is knowledge I would like to build up.
Will do when I get home, don't know why I didn't take one last night. There are no buttons on it basically wires going in, wires going out.
I just worked on a fire place very similar to this one and the little box you are referring to has a switch with off, remote and manual positions.
Well unfortunately there where no knobs on the little box, ill post pics in the morning. The box was warm to the touch so I know it's got juice. Turned on the main gas, bottom gas, on switch, flipped the wall switch and nothing not even a click.
Well it was pretty frustrating yet again for another night.
Here is the pic you guys requested, thanks for all your help.
http://i49.tinypic.com/2lc89xd.jpg
Turn your gas on, flip the switch on, turn the wall switch on. when you do that it should begin sparking at the pilot, if it doesn't the module could be bad, the wall switch could be bad and/or you are getting no power to the module.
oops missed the second page, the last picture is a transformer, that powers the valve. the brown wire that runs in the side of the firebox on the last picture, where does that hook up?
