Originally Posted by
udarrell
A men to that, motoguy!
Let us look at summer designs at Miami FL compared to Madison WI: Miami is 90 & 77-WB for a 13F drop for 56% RH, with a 111F Heat Index; Madison WI is 88 with 73-WB a 15 drop for 49% RH with a 102F Heat Index.
However, we get real high Heat Indexes: National Weather Service Weather Forecast Office, Temperatures during the July, 1995 heat wave pushed into the 100 to 105 range across South-central and Southeast Wisconsin, while muggy air with dewpoints in the upper 70s to lower 80s added to the discomfort. The combination of heat and humidity resulted in heat index values peaking in the 120 to 128-F range; probably the highest values in Wisconsin recorded history.
The duration of the heat wave and the stuffy overnight conditions amplified its affects on humans, since it became difficult to recover at night from the daytime affects of the heat.
Heat waves in Florida typically occur during periods of drought, low humidity and mostly clear skies.
In June 1985, a severe heat wave hit the state with temperatures of 106˚F in Ocala and 105˚F in Lakeland.
Another prominent heat wave struck in 2011 when Tallahassee hit an all-time record high temperature of 105 degrees on June 15.
The highest heat index temperature reported in Florida in 2010 was 124˚F in Apalachicola on July 31.
Therefore, Miami's extremes are no worse then mine in SW WI.
In my 1937 farm home I have a little Half-Ton window unit cooling 1300-sf "PER-TON" at 124-F Heat Index or some-what higher; it kept it within 78-F & around 55% RH, very comfortable.
Therefore, it would seem to me something is way wrong if you can only keep people comfortable at 400-sf per ton!
Got to get off power company is going to work on Transformer!
