Constant fresh water is a steam boiler killer.
Printable View
just a thought, access the highest point of the piping (attic) see if there is a vent there.
condensed steam is distilled water, no chemicals or sediment from that... the fill water will have innumerable additives, and just plain muck. it's NOT good for the boiler, it's VERY BAD to constantly have water entering the boiler.
You guys are the best... Thanks for your help and looking out for me!!!!!!!
Thanks for the info..... I'm trying to find the problem.... And I wont sleep till its rectified!!!! Thanks again... Frank S
Will look into the problem when we get back to the cottage on 12-26..... Thanks again..... Much appreciated.... Frank S.
No, I had not thought about vented risers in the attics. If the cottages are both two story, and the seven garages single story, what would be the reason for vent risers in the attic...... Thanks for you concerns and thinking out loud..... Frank S
If after everything you still can find no leak, I would check the boiler sections to make sure your leak is not there. A leak between the sections would not be seen due to evaporation. Although I think a 20 gallon leak between sections would have been noticed.
Leaks in steam and condensate return lines are sometimes very hard to find if the pipes are covered with insulation and some insulation is worse than others. Steam can leak and evaporate without visible signs through the insulation. The same can happen with condensate return water depending on where the leak is. Some insulation is a very good wicking material and the moisture will evaporate from it without showing you even a wet spot on the outside.
Temperature differences in a length of piping (with insulation on it) is almost always a dead giveaway. A simple infrared thermometer can help pinpoint these leaks. Wherever the leak is that spot in the insulation will be warmer. Of course a thermal imaging device of some sort is even easier and quicker.
