I'm looking for a heated condensate drain pan for a walk in cooler.This pan needs to mount on the back outside wall of the cooler.I've seen one years ago,that was 6 feet long 6" wide.Cant find one now,yall got any suggestions.
Printable View
Try Case parts. they have an online catalog. good luck
Case has some. I bought one technically made for a Norlake last year. I would try to find a way to pump the condensate away.
Heatcraft sell a smallish one off the shelf over here.
depending on the size of your room it could do the trick.
Failing that, get your local sheet metal company to knock you up a stainless steel pan, put a defrost heater in it and control it with a thermostat and perhaps a fan to speed up evaporation and get rid of the water vapour.
You could also try controlling the heater with a float switch...
Thanks fellas!! i figured i would have to get a sheet metal shop to make me a pan ad fabricate a heater and t-stat set up. Unless MicahWes can give me a part number from case parts. Their catalog don't show one and moss at case cant come up with what im looking for either.
Try 3wire.com I order a lot of this type stuff from them.
