Originally Posted by
ddalberto
Sometimes the warranty might be different. We install mostly Ruud. Lifetime warranty on heat exchanger. Weathering is the same thing, a little cheaper and I think 20 years on the heat exchanger. Other than that....same unit.
I used to work at carrier in Syracuse NY back in the '80's. when we switched from Carrier to Bryant, the only things we changed out were the data tags and the badges. The actual units sat on the assembly line while we changed them.
With that said though, be careful because there is some junk out there.
