Originally Posted by
stant_98
George2 and all others who responded - thank you! Your expertise is highly appreciated.
I had an HVAC contractor look over the furnace and the ducts today.
He recommends to install a return specifically for the basement,
i.e. hook up the duct from the other side of the furnace
(there is already a main return hooked up to the other side).
So he recommends to install a dedicated return for the basement as well as repositioning ceiling registers -
moving them closer to the exterior basement wall.
He also suggested fixing one flex duct that connects adjacent bathroom.
He did not perform any tests or measurements,
but said that according to his experience - there will be some airflow improvement.
Another option I have is for $$$ to have a comprehensive energy audit and duct analysis done.
$0 - energy audit per system = $0 ($350 subsidized by my local utility co.) My cost $0
$0 - duct analysis for the downstairs unit/ducts only.
$0 total
Should I get both done or since this appears to be airflow problem, just get the duct analysis and then,
based on the findings, make improvements? Thanks again!
