Originally Posted by
Twit
Thanks for your reply.
So, the max. face velocity is the maximum speed the air exits the face? Yes
The Max Supply Outlet Face Velocity should be 700 fpm (Manual D). If you exceed this, you will probably have noise issues.
Ak - This is the dimensions of the damper under testing?
Effective area (Ak), is the area of the register, grille, or diffuser in square feet that is utilized by the air flowing through it.
When air flows through the bars or louvers of a product, it is compressed slightly between the bars, and there is some friction as the air makes contact with the bars as it flows past. This has the result of reducing the total area available for the air to pass through. Effective area is usually less than free area for the same product because of these reasons.
