So did you install the flame retainer and regulator?
Never mind missed the last post
Printable View
Interesting thread. Draft motor rotating the right way?
Sent from my SCH-I800 using Tapatalk 2
Is this natural gas?
I would also check to make sure the draft motor is the same, rpm, wheel, rotation ect.
To slow tonight I guess.
i dont believe carrier. i called them yesterday about a motor mount kit. They swore up and down that this motor mount kit worked for the same unit i replaced the heat exchanger. I called them and verified the part I had in hand would work.
Well guess what. It didn't work. I couldn't even rig it to work.
On the talk of carrier. Anyone have the parts app? It's been good so far. One of the carrier distributors around here has a very lackadaisical counter guy. When I'm forced to go through him I have found to sometimes double check because he has screwed up. For instance quoting me a 3ph cond motor when I knew for a fact the one in question was 1ph. Anyway, its the CE app
for your unit i see a flue baffle in the parts list
flue baffle; 48GS500114
and NOx baffle
insulation; 48SS500601
how many pipes on bottom did you h/x have?
I would try the 2 parts i listed above
2
i noticed that both part #'s have a 500 in it but the part #'s i have for two of the parts have 400 in them. Such as the inducer fan assembly is a 48gs400649 and the flue box collar is a 48gs400108. I do not know if this means anything?
sorry about the slow responses, I just had my first child two weeks ago and I have been trying to spend some time with him!! It is natural gas. That is a good idea on the draft motor. I will check that!
your parts numbers are right and the ones i gave are correct.
the new heat exchanger comes with the NOx baffle. so dont worry about that.
i would try the flue baffle. ill send you a pdf
congratulations! I have my second one on the way in May. don't know the sex yet.
have you checked the orifices?
