I dont see anything wrong with his system, maybe the drawing is rough and maybe missing some items but it has one main loop with one pump and 3 secondary loops with individual pumps.
Printable View
I was thinking that there was one pump and then zone valves. If it is all pumps then it is still wrong although it isn't as bad as it would be with valves. The entire system can be run with one pump so having 4 doesn't make sense and if they were all circulators then there would only need to be three unless there was a re-circulation loop which there isn't due to the fact that there would be a mixing valve within the only possible loop.... which (again) makes me believe that it is one circulator an three zone valves.
I see that he put a circle as pump but he only designated one circle properly with the triangle within it. It's all so convoluted I just went to logic over stated.
If you are correct then I can see why at least one kick heater is getting smoked and the flooring is getting robbed. ;)
Attachment 339731
Here is the high side version.
Depends on your design, as to what you run. I dont like the blast furnace effect from kicks. When I do use them it's for cold spots, not area's. Toe heater is how I sell mine and that's all I expect from them.
