Consolidated industries piece of **** furnace. Must have broke off the fitting at some point. Not sure why a shotgun shell was used to keep it in place but it was.
http://farm9.staticflickr.com/8326/8...e57af2b3_b.jpg
Printable View
jerry rig 101
Wow. Hey at least it was already shot?!???
Sadly not shot thru the furnace. I hate working of them pieces of ****.
For real?
This one is my furnace. It no longer has that pesky condensate separator.
Attachment 318801
Thats a 20 gauge, skimper should used a 12 gauge!
Nope, part of the dining room that was walled in as a closet with studs and paneling with a return grille. There is no return ductwork, just 2 20x25x1 pleated filters (not 3M Crack-O-Matic) in an A frame shape on top.
The wallpaper is peeling from the lath and plaster wall because the roof leaked around the old brick chimney, which they ran the single pipe CPVC vent up through. I am going to re-roof with tin, get rid of the chimney, and go with a 3" concentric vent through the side wall, then hopefully get rid of the downflow furnace and ducts in the crawl in favor of an upflow 2 stage 95% with the ducts above the 2x4' tile lowered/false ceiling.
Note that the gas line has no sediment leg, and yes that is light gauge cat3 for the thermostat, but the cable is only ~6' long.
I consider this furnace like a Daewoo car, its manufacturer may be DOA, and it isn't very good, but as long as it works properly who cares?
:grin2:Now there is a market for spent shells...recycle as spacers for HVAC equipment, or other mechanical trades. Just don't use the unspent ones, unless absolutley necessary (they come with an applicator tool:grin2:).
