Originally Posted by
Tech Rob
You should be prepared to spend thousands on equipping yourself with the best stuff money can buy. I like to use my own stuff so I am not stuck using whatever junk the company wants to supply. As long as there is an agreement that the employer will cover maintenance/repair/replacement cost if it's used on the job.
I think most self-respecting techs own their own drills, saws, gauge manifolds, torch set, scale, leak detector(s), meters, thermometers, etc. in addition to the standard hand tools. Vacuum pump could go either way. Recovery machine & cylinders usually not. Your tools are an investment in your ability to do your job without being dependent on someone else. I would have a hard time taking someone seriously as a professional if they did not make this investment in themself.
Just for illustration purposes, here's what I roll with every day. Can handle most service calls with just what's on the table there.
