Originally Posted by
richard.bessey
Ah, I think I now understand.
Basically your advise is to have sensors and controls in place, should a leak/malfunction happen, shut down systems and waterflow to reduce the amount of damage, correct?
We really have no central monitoring of the heat pumps. We have one honeywell controller that controls wether to run the cooling tower or boilers based on the loop temperature.
A then small controls on the boilers and cooling tower to control the pumps/fans/burners on those units.
The heat pumps are stand alone units with thermostats and simply put heat or cold into the water, depending on demand. Its a very simple, yet complex system.
Again, I really appreciate the info you provided.
