Yes, I know that. That's not the point. The point is my a/c isn't working. But thanks for the tip.
Printable View
You need to have a proper leak check done and when the cause of the leak is found, then you can have it fixed or if it's large enough (like a leaking coil) you can make the decision then.
If the contractor you had didn't explain you have a leak and the fact that nobody knows how long it will take to leak out, shame on him.
Sent from my iPad using Tapatalk HD
The only thing your contractor is guilty off is not telling you clearly that he did not look for the leak or fixed the leak.
When I have not seen a system before, I normally always just charge up the system to see how quick it will leak out. It can take a day or it can be years.
Your contractor can not know how large the leak is. Now, when you call him back, he will know and he will have to see, if he can fix the leak or you need a new AC.
WOW! I can't believe some of you, maybe because I do only commercial, I don't "gas and go". It is actually against our companys policy. We may put off a leak check, but we always return to do one. It's part of a service call.
Sent from my DROIDX using Tapatalk 2
Additional infractions may result in loss of posting privileges.
Too Funny. HVAC service 101, How to Make Money. Find and repair the problem.
BMartin9000
