Originally Posted by
jamesjohan
Hi,I also never wired a duct smoke detector but A my friend suggest me for the wiring of the smoke detector,so Determine the smoke detector's input voltage. The fire alarm system's control panel, located near the air handler, lists the smoke detector's input voltage and labels the control system's wire terminals. Usually two sets of wires extend from the management panel's wire terminals. One set leads to the smoke detector's input power supply and the other leads to the smoke detector's alarm circuit. In some cases, the smoke detector receives its input power from the air handler. Check the control panel's wiring diagram to verify the input power's source.so may it prove helpful for you.thanks
