thermostats reach in coolers
im more familiar with the thermostats where the sensing bulb hangs in the return air stream and of course senses the temp inside the box (cooler). then there are the kind that the bulb touches the evap coil. and works off of coil temp im starting to see more of them on newer equipement or maybe its just me. whats the pros and cons there has to be something for them to choose one over the other one. while building these units, also i see some pieces of equipement once it reaches temp the evap fan shuts off. whats the benefit toward that. if it stayed running it provides defrost for the evap coil while off on temp. also keeps the air constantly blowing over the product in the cooler. but im sure there is a benefit to it, looking forward to hearing your input/ knowledge....
