The only realistic answer is the the evacuation time wold decrease "noticeably". The variables are just too numerous to give a pat answer.
Printable View
I have always known them to be the exact same thing. I only spent five minutes looking just now, but I don't see anything on the internet that says any different.
Sent from my ADR6350 using Tapatalk 2
How often so you guys clean your micron gauges?
i wanna buy one whats the company who makes it?
Something to remember:
I have the appion flow rig with 1/2 hoses, an appion vacuum pump, and a bluvac.
I was recently working on a small system (double door reach in cooler) after a compressor change-out, and was only able to get to 1000 microns.
I was trying everything. Tightening all hose connections gorilla tight. Nitrogen purging. Leaking king valve stem? Leak somewhere else?
Then I took all my hoses and connectors apart, and dabbed some Nylog on the ends. (it's been a few months since I did this)
Hooked back up, went down to ~300 microns in 20 secs.
Lesson learned.
I have used the Nylog. I am afraid it is going to clog the port. In the video on the website they use it on shraders. It is pretty thick stuff. Especially the one for r-22. Has anybody ever had a problem. When I use it on the face of flares it looks like it will clog the pipe. This makes me afraid to use it on shrader ports.
I am testing out nylog Tommorow for the first time. I didn't like how I had to buy to different kinds.
So what is the part# for the tee that everyone uses for their vacuum setup?
OldSchoolMech. Just use the blue nylog HFC. it will work on both 22 and 410. it is also easier to work with. the red stuff is super tacky
