Originally Posted by
Shophound
There are tests available that can inform a person how healthy a compressor might be, but the effectiveness of those tests toward this end depend on at least two factors: a) interpreting the results of the tests correctly, and b) end user willing to pay for the tests if an extra charge on top of a service call is presented.
So what are the tests?
a) Megohmmeter - aka "megger", not often used in residential work but can inform the tester as to the health of the compressor motor windings.
b) Acid and moisture test - informs the tester if the oil in the system is acidic and/or contains moisture. Acids form in compressor oil either due to moisture or excessive heat, or both. Elevated levels can sometimes be managed by changing the liquid line drier in the system.
In your case, if the internal overload has weakened due to the recent stress it suffered from the failed fan motor, you could also have elevated acidic levels in the compressor oil. Typically, not many homeowners are willing to pay for efforts to prolong the life of a compressor potentially at risk, but some may. From that point it's a matter of finding a tech who can properly administer and interpret the tests, and inform you, the end user, what those tests indicate as to the health of your compressor.
This is why I recommend for you to ensure the condenser coils are clean. You want to reduce stress on the compressor by enabling it to get rid of heat more effectively. That's what clean coils can do, and may enable you to get through the hot afternoons without the compressor cutting out on overload.
