Check the discharge temp if it's like 90°. Your flooded!!!
Printable View
I will do that when I return. What's a good guesstimate for proper discharge temp ?
190° sounds good!!!:grin2:
What's odd is your low lo side!! If the indoor metering device was bypassing you would think your low side would be higher!! :confused:
I just looked at Carriers troubleshooting chart for this model. It points towards LOW CHARGE :eek2: for low suction pressure. Or dirty filters,dampers partly closed,duct restricted,indoor coil frosted,liquid line restricted,piston restricted,indoor coil screen restricted. :gah:
Well I'm going to call it a day. I'll keep ya posted how it turns out and thanks for hanging in there with me. :cheers:
