Originally Posted by
EddyCurr
Mess ? Why "mess" ?
I looked back a bit in your previous posts for recent photo examples of current
best practices without success. However, judging by what appears in threads
posted by other owners, current practice comes up short compared to what
appears in the photos above.
And what determines useful life? Those furnaces are just some sheet metal
boxes with motors, blowers, valves, burners and heat exchangers inside.
It is not uncommon here for ambiant temperatures to drop below -40ºF
and then remain there for ten to fourteen days each January - the equipment
shown works on demand and keeps the building and occupants comfortable
when that happens. It does so at a fuel and electrical cost that is tolerable.
As I anticipate will be confirmed about the A/C units, changing out the
furnaces in favour of current equipment will not be a trivial matter. Far
from just an R&R of suitably sized furnaces, with THIS home, there will
need to be a wholesale redesign of the fresh and combustion air
supply/venting with attendent demolition and renovation involving numerous
trades to accomplish same, along with headaches about how to deal with
cosmetic issues regarding location of the chimneys and so on.
In due course, that day will come. However, it seems a bit premature to
set off on that expensive course of action when all I appear to need is a
compressor replacement for the m/f unit.
I am at a stage in life where there is every chance that I will be looking for
different lodgings within ten years. Recouping the kind of investment required
by a wholesale refit through personal enjoyment or added resale just doesn't
seem likely to happen.
My goal is to restore the functionality of the m/f unit so that for the 30 to 45
days of each year that we experience 80ºF+ days with high humidity the 2nd
floor unit is not having to carry the entire cooling burden, I can relax rules
against oven, d-washer and dryer use during daylight hours and there is back-up
refrigeration on hand in the event that a problem brings down the 2nd floor unit.
Thank you for the replies.
