Carrier Fixed Orifice Header Replacement
So I see a lot of post about these things so I thought I would photo document the repair I did this morning on a Carrier 10 ton, Circuit 1. I also wanted to show how relatively easy it is to change these things out.
First pic is me holding the replacement part.
http://i1173.photobucket.com/albums/...717_085555.jpg
Second the instructions.....tossed them right after I took the pic. It was a 40 foot roof and a windy day so I expect they're in Corpus Christi now. I live in Houston. I don't need Carriers help.:whistle:
http://i1173.photobucket.com/albums/...717_112318.jpg
This is the offending article. Bottom header. Notice the "imps" ? I got impatient and broke out my set of Kline dikes and made quick work of the rest of the tubes cutting after the crimped in orifice.
http://i1173.photobucket.com/albums/...717_093650.jpg
Header is cut away from the coil. Cut it away from liquid line and now it's time to remove the stubs. Used a #1 tip, low heat and a set of channel locks.
http://i1173.photobucket.com/albums/...717_094849.jpg
This is the Evap coil minus it's fixed orifice header and the stubs and it's ready for the new header assembly.
http://i1173.photobucket.com/albums/...717_100130.jpg
New header lined up but not sweated in. A little adjustment and it fit like a glove.
http://i1173.photobucket.com/albums/...7_100343-1.jpg
