Blodgette Oven F2 error.
I replaced the Ignition control because the Oven didn't have 24V to the MV. Now it does and the burners come on, but the oven does not stop at oven set point it just keeps getting hotter and hotter till it errors out saying F2 on the display. Any suggestions?
In domestic there is a oven sensor that cycles the tempature. If there is one it would be suspect. Get the owners manual or service manual, it will tell you the failure per defect code. If those are not available contact the manufacture or do a web search.
:putergreet:
Maybe the temperature probe or the t-stat is stuck closed. If you stock parts swap them in and see what happens, if you don't I would order both of them and it should take care of the problem.
