Guess I know what I'll be doing tomorrow. :gah:
Printable View
Been there done that, I assume your combustion motor is fried as well. Do you have the most recent service bulletin for that scenario??
I knew there was a service bulletin at some point, couple years ago right? I called my Trane locally and he said replacing the combustion blower will end all my problems. Was that the fix, new combustion blower motor? I thought there was some sort of relay kit as well.
Here you go, kit part numbers are included. I had to replace every board and both the high voltage and control wiring harnesses on the last one I did. Trane however came good for all of the parts because it was less than 5 years old.
I also fused that transformer as there is no overcurrent protection from factory.
Replace that turd with some real equipment. Not that hard to stop after all.........
Sounds like your not sure how to proceed with the repair, just use the skill you know you have, jump in & learn from it.
