Printable View
Quote: Originally Posted by jpsmith1cm The Henry helicals are pretty good separators. Does it have a flange on the bottom of it? If so, you may want to pump it down and pull that float plate and clean or replace it. They get junk in them and stop up. check to see if it has bolts on top as well, if so there is a filter in it. (take a pic and post)
I know there was a bottom flange that could be removed. I don't believe there was any bolts on the top. They shut the system down at the end of April and will probably have some time to get into it and check things out. Quote: Originally Posted by emcontrols check to see if it has bolts on top as well, if so there is a filter in it. (take a pic and post)
Quote: Originally Posted by emcontrols check to see if it has bolts on top as well, if so there is a filter in it. (take a pic and post) That Henry separator does not have a filter in it. I'm quite familiar with it. When you've got it open, there is a screen up inside it. Pull it out and clean it, too. Also, make sure to install the Pre-charge. I attached Henry's Oil Control Booklet. Good info.
