Originally Posted by
Homeowner314
The unit is nearly perfectly centered in the house.
The plenum is 15x20 at the unit, going into a huge box that merges into a trunk going to each end of the house. I'm simply guessing here, but wouldn't be surprised if the two trunks were 8x20 or 8x24, or maybe 10 high. I'm taking a stepladder to check out the ceiling insulation Monday, I'll measure the trunks then. Normally I'm in the attic before bidding, but this time the PO glued the access port shut with Great Stuff.
The return grids are on each side of the central hallway, right above the unit. After they merge into one duct going to the unit, it's 23 inches wide, and I think eight or ten inches thick. Should I get a quote for setting up return trunks and branches so the returns function better with the doors closed? This might be getting expensive.
