Excellent. You might try using the suggestions from my earlier post if you have it occur again, it might save you from re-installing.
Printable View
Thanks Graham
yea ill try that if it ever happens again. thanks.
do tapatalk signatures not work on this forum?
They should, once I get my phone back from sprint Ill be able to play with it...Ive been using Tapatalk for about 6mths on other forums...
Hey guys...
Just an FYI. Signatures are controlled by this site so don't put anything in your sig file that would would be against any rules here such as advertising, competitive sites, non G rated and stuff like that. thx
This looks like it was an issue with the hvac-talk configuration on tapatalk. If the setting change I just made worked signatures should now be working.
If you scroll through the Wiz's post here you will see he has a sig in most of his post but not all... It must be working.
OK, so... remember guys... nothing I will be forced to delete, yes? Thanks.
that's this forums signature setting. tapatalk also has the option so i had the one from this forum blank .. really isn't a big deal but i was curious if maybe this forum doesn't allow sigs from such apps as tapatalk. ..... don't think u will be deleting anything i have to say
Testing.. signature should show up
Sent from my PC36100 using Tapatalk
so you have the Android version .. I'm running v1.13.5 .. u? .. what's the setting for your signature in the reg forum?
I dont know what version I am using but it is on android. The Tapatalk Signature is setup in the setting on the tap a talk app. It is actually inserterd into the text of everymessage as the same with a signature on an email.
