Originally Posted by
udarrell
Ask what the county code guys would do about an A/C contractor that, because there was no open place for a breaker, the A/C guys bypassed the main disconnect & connected directly to the conductors coming from the meter & the 600-Amp fused main supply transformer.
Those small conductors were not even placed in conduit, they looped around in the basement & connected to a fused breaker box there &, then ran to the outdoor disconnect near the condenser.
Have you ever heard of a worse violation of the EC Code?
There was a fused 220-volt conductor running to the living room to a 1.5-Ton window unit; the central condenser is 1.5-Ton & pulls a lot less amps than the window unit pulled which they no longer use.
They could have used the breaker location or run those conductors to the outdoor disconnect by the condenser.
So someone trips the main breaker off & think the power to the basement breaker box is killed or, that power to the A/C condenser is killed, instead they may be electrocuted/killed. A hidden death trap...
This was out in the country with NO inspection permits pulled...
